11 years agocan not export the master interface of avalon-mm pipeline bridge
I need to make Qsys export an Avalon-MM Master for configuring a IP core which has a Avalon-MM Slave interface, but I got this error from eclipse while downloading the software: No Nios II target ...
11 years agoWhat are the reset and exception memory settings in NIOS CPU? Did you try to connect to on-chip memory for testing?
