11 years agocan max10 use outside flash as configure flash?
max10 has internal flash, but i think it may not big enough for some applications so can max10 use external flash as configure flash? how can i make the connections?
11 years agoBy "soft configuration file" you mean the code that the Nios will run? I don't have much experience with Nios on small devices like this, but as far as I know you can use an external flash to store the Nios software. Someone else will need to confirm this.
