10 years agoC2H Request !
Hello mates I managed to develop my C code using nios II (Quartus 13.0 web edition), as far as I know I should accelerate the functions using HDL. I thought there is a tool C2H compiler for Alt...
10 years ago --- Quote Start --- Another option would be to install older Quartus, in parallel with your existing install, so you can evaluate the tool and see if it is going to help you the way you hoped it would. If you are satisfied, taking the results forward into 13.0 is no problem as the output files are clear text. --- Quote End --- Much appreciated ! thnx
