16 years agoC2H hardware acceleration tutorial problem
Hello, I'm attempting to run the c2h FFT hardware acceleration tutorial as described in: http://www.altera.com/literature/tt/tt_nios2_c2h_accelerating_tutorial.pdf
Upon building the project I get the following error message: Severity and Description Path Resource Location Creation Time Id C2H C2H ERROR: connect_variable pragma for accelerator_optimized_fft/BufferedRealCalcDataRead specified module BufferRAM1, which does not exist. at file: , line: c2h_fft line 0 1259519543367 136 Since the description tells me that the error occurs at line 0, I cleaned the project, which didn't fix the error. I've followed the tutorial precisely, and properly named the BufferRAM1, but still the same error message. Can anyone give me some insight? Thanks in advance.2 Replies
Did u manage to get it working , did you had any issues with the results ? am getting on wrong results ?
hey,
I got the same problem that you use to have. can you please tell me how you fixed it?
