16 years agoC2H compiling error
I built my C code with cycloneII SOPC design in NiosII IDE without any problem and I can see the result in ModelSim..but when I want to accelerate a function(loopH) of my code using C2H,it doesn't bu...
16 years agothank you dsl..you were right.I shifted all of the variable definitions to the start of program blocks and that error vanished.but after building the project I faced to another error which doesn't point to my code lines..!!
___________________________________________________ ERROR(PROBLEMS TAB): make: *** [c2h_hdl-t] Error 254 ___________________________________________________ contexts of (console tab): Info: Wrote G:/Nios/standard/NiosII_cycloneII_2c35_standard_sopc.sopcinfo Info: NiosII_cycloneII_2c35_standard_sopc: Wrote G:/Nios/standard/NiosII_cycloneII_2c35_standard_sopc.html Info: NiosII_cycloneII_2c35_standard_sopc: Generating QIP file. Info: Info: ******************************************************************* Info: Info: Running Quartus II Shell Info: Info: Version 9.1 Build 222 10/21/2009 SJ Full Version Info: Info: Copyright (C) 1991-2009 Altera Corporation. All rights reserved. Info: Info: Your use of Altera Corporation's design tools, logic functions Info: Info: and other software and tools, and its AMPP partner logic Info: Info: functions, and any output files from any of the foregoing Info: Info: (including device programming or simulation files), and any Info: Info: associated documentation or information are expressly subject Info: Info: to the terms and conditions of the Altera Program License Info: Info: Subscription Agreement, Altera MegaCore Function License Info: Info: Agreement, or other applicable license agreement, including, Info: Info: without limitation, that your use is for the sole purpose of Info: Info: programming logic devices manufactured by Altera and sold by Info: Info: Altera or its authorized distributors. Please refer to the Info: Info: applicable agreement for further details. Info: Info: Processing started: Tue Feb 09 01:24:06 2010 Info: Info: Command: quartus_sh -t sopc_add_qip_file.tcl Info: Info: Evaluation of Tcl script sopc_add_qip_file.tcl was successful Info: Info: Quartus II Shell was successful. 0 errors, 0 warnings Info: Info: Peak virtual memory: 102 megabytes Info: Info: Processing ended: Tue Feb 09 01:24:06 2010 Info: Info: Elapsed time: 00:00:00 Info: Info: Total CPU time (on all processors): 00:00:00 Error: Can't create file G:/Nios/standard/NiosII_cycloneII_2c35_standard_sopc.ptf Error: System generation failed. make: *** [c2h_hdl-t] Error 254 Build completed in 157.569 seconds
