20 years ago
Building a Linux Application Project
Hi fellows ,
I want to build a Linux Application on NIOS 1c12 evaluation kit using NIOS IDE 5.0
My project has got 2 files : main.c and add.c
In main.c :
int main()
int a , b;
a = 5 ;
b = 7 ;
printf("%d + %d = %d" , a , b , add( a,b ));
return 0;
In add.c :
int add( int a , int b )
return ( a + b );
There are 2 actions I should do : Build Make Target and Build Project. Is it true ?
For "Build Make Target" , here are my steps :
- Choose Build Make Target from the context menu after right-clicking my project folder in NIOS IDE
- In "Make Target" window , I choose "Add"
- I enter the string "main" in "Target Name" and "Make Target" fields , then OK
- Then Build
- I got this error message :
make -k mp3e_main
gcc mp3e_main.c -o mp3e_main
make: *** [mp3e_main] Error 255
For "Build Project" , I got the following error :
make -k all
make: *** No rule to make target `all'.
My question :
Could you please show me the ORDER of these actions and details of each one ?
Any helps would be much appreciated.
Quan
    Read the tutorials and everything will be alright. And also take a look at code examples. Everything is explained. The only thing to do is to review the documentation.
    Thanks HelmChen for your reply.
    After uploading my application to NIOS uClinux , I want to debug my application but *.gdb hasn't been created in NIOS IDE.
    I added this code to Makefile as the document suggests but nothing happened :
    CFLAGS += -O0 –g
    all: app.exe app.gdb …
    What should I do to create that *.gdb ?
    Quan
    If you do it like in the examples, you don't to add a line: Set DEBUG=1 in the makefile.
    But i don't know how your Makefile looks like...
    Hi ,
    This is my "makefile" :
    # # configurable options# - set DEBUG = 1 to turn on debugging support#
    DEBUG = 1
    PROJ_NAME = myapp
    INSTALL_DIR =
    PROGS := $(PROJ_NAME).exe# CFLAGS +=
    cflags += -o0 -g
    # # You should not need to modify anything beyond this point#
    TOPDIR = .
    include $(TOPDIR)/Rules.mak
    ifeq '$(DEBUG)' '1'
    PROGS += $(PROGS:.exe=.gdb)
    endif
    # all: $(PROGS)
    all: myapp.exe myapp.gdb
    .PHONY: clean
    clean:
    -rm -f *.[oad] *.elf *.gdb *.bin *.exe
    .PHONY: install
    install: all
    ifeq "$(INSTALL_DIR)" ""
    $(error No installation directory specified)
    endif
    mkdir -p $(INSTALL_DIR)/bin
    install -v $(filter %.exe, $(PROGS)) $(INSTALL_DIR)/bin
    I can easily create a gdb and debug my HelloWorld application with this makefile, but when I use this for a bigger one of mine , I cannot create it.
    I tried to remove ".PHONY: clean ... " but things are not better
    This is "Rules.mak" :
    # ########################################################################## Variables and Rules for building Nios II Linux applications# # This file is a "template" that is copied over from the Nios II Linux# Application plug-in. This file should be included within your top-level# Makefile.#
    ifeq "$(origin TOPDIR)" "undefined"
    TOPDIR := $(shell pwd)
    endif
    # # The Settings.mak file is automatically generated by Eclipse. It# contains values for all external variables used by this Makefile# fragment.# # The "dash" in front of the include statement indicates that the Make# process will not terminate if it cannot find the Settings.mak file.#
    -include $(TOPDIR)/Settings.mak
    # This turns on various levels of hardware multiply support# Set the following option to none, mul, or mulx# none := no hardware multiplication support at all# mul := supports use of the mul assembler instruction# mulx := supports use of the mul and mulx assembler instruction
    ifeq "$(HW_MUL_SUPPORT)" ""
    HW_MUL_SUPPORT := mulx
    endif
    # # Warn users if external variables have not yet been defined.#
    ifeq "$(origin UTILSDIR)" "undefined"
    $(warning The location of the utiltiies directory is undefined)
    endif
    ifeq "$(origin LIBCDIR)" "undefined"
    $(warning The location of uClibc is undefined)
    endif
    # # Path + Name of necessary executables#
    EXECSUFFIX := .exe
    CROSS := nios2-elf-
    CC := $(CROSS)gcc
    AR := $(CROSS)ar
    LD := $(CROSS)ld
    NM := $(CROSS)nm
    RANLIB := $(CROSS)ranlib
    STRIPTOOL := $(CROSS)strip
    ELF2FLT := $(UTILSDIR)/bin/elf2flt
    # # Location of important files#
    CRT0 := $(LIBCDIR)/lib/crt0.o
    LIBC := $(LIBCDIR)/lib/libc.a
    LIBGCC := $(shell $(CC) -print-file-name=libgcc.a)
    LIBM := $(shell $(CC) -print-file-name=libm.a)
    LIBGCCDIR := $(dir $(LIBGCC))
    LINKSCRIPT := $(UTILSDIR)/scripts/elf2flt.ld
    # # Various flags, modifications are not recommended and not necessarily# supported.# # DEPFLAGS:# -MM : ignore system includes, # -M : include system includes in the dependency#
    WARNING_FLAGS := -Wall
    # basic C flags to pass to the compiler
    CFLAGS += -nostdinc -D__linux__
    # if DEBUG is turned on, then turn off optimizations and turn on symbol# generation, else turn on level 2 optimizations
    ifeq ($(DEBUG),1)
    CFLAGS += -O0 -g
    else
    CFLAGS += -O2
    endif
    # pass any additional include directories to the compiler while building the# application
    CFLAGS += -I$(LIBCDIR)/include -I$(LIBGCCDIR)/include
    # Temporary workaround for nios2-elf-gcc bug# First noticed in v3.4.1 (Altera Nios II 1.1 b131)# To be removed at a later date when bug is resolved.
    CFLAGS += -fno-optimize-sibling-calls
    # Turn on the various levels of hardware multiplication support.
    ifeq ($(strip $(HW_MUL_SUPPORT)),none)
    CFLAGS += -mno-hw-mul -mno-hw-mulx
    endif
    ifeq ($(strip $(HW_MUL_SUPPORT)),mul)
    CFLAGS += -mhw-mul -mno-hw-mulx
    endif
    ifeq ($(strip $(HW_MUL_SUPPORT)),mulx)
    CFLAGS += -mhw-mul -mhw-mulx
    endif
    mulx_help_text := $(shell $(CC) --target-help | grep mulx)
    ifeq "$(mulx_help_text)" ""
    CFLAGS := $(filter-out -mhw-mulx -mno-hw-mulx, $(CFLAGS))
    endif
    DEPFLAGS = -E -MM
    LDFLAGS := -msys-crt0=$(CRT0) -r -d -L$(LIBCDIR)/lib
    LDLIBS := $(LIBM) $(LIBGCC) $(LIBC)
    # relocate the absolute elf file if requested
    ifneq ($(TEXT),)
    TEXT_LOC_OPT := -Ttext $(TEXT)
    endif
    ifneq ($(DATA),)
    DATA_LOC_OPT := -Tdata $(DATA)
    endif
    ifneq ($(BSS),)
    BSS_LOC_OPT := -Tbss $(BSS)
    endif
    # default stack size is 4K
    FLTFLAGS:=
    %.exe : %.flt
    cp -f $< $@
    # # Make a relocatable flat file from an ELF file.# STACKSIZE is defined by individual makefiles.#
    %.flt : %.elf
    $(ELF2FLT) $(FLTFLAGS) -o $@ $<
    # # Make a bound-address ELF file required by GDB for debugging the application.#
    %.gdb : %.bin FORCE
    $(LD) -T $(LINKSCRIPT) $(TEXT_LOC_OPT) $(DATA_LOC_OPT) $(BSS_LOC_OPT) -o $@ $<
    # # Make a relocatable ELF file.#
    %.elf : %.bin
    $(LD) -T $(LINKSCRIPT) -Ur -o $@ $<
    # # Standard stuff: The object file is dependent on the C source and Makefile timestamps#
    %.o : %.c Makefile
    $(CC) $(CFLAGS) $(WARNING_FLAGS) -c -o $@ $<
    %.o : %.cpp Makefile
    $(CC) $(CFLAGS) $(WARNING_FLAGS) -o $@ $<
    %.bin : %.o
    $(CC) $(LDFLAGS) -o $@ $^ $(LDLIBS)
    # # Automatically generate dependencies for the .c source files.# Be sure to omitt debug-level flags as this can produce macro def&#39;n output.# The sed "script" makes the .d (in addition to the .c) file a# target of the dependencies so that the .d file is rebuild if required.# e.g. "X.o: <dependency-list>" gets transformed into "X.o X.d: <dependency-list>"#
    %.d: %.c
    $(SHELL) -ec &#39;$(CC) $(DEPFLAGS) $(CFLAGS) -c $< | sed &#39;\&#39;&#39;s/\($*\)\.o[ :]*/\1.o $@ : /g&#39;\&#39;&#39; >$@; [ -s $@ ] || rm -f $@&#39;
    FORCE: ;
    I tried to remove "rm -f ..." (letters in bold) but *.gdb is still not made.
    It seems to me that *.gdb has made but was removed somewhere before makefile & Rules.mak complete.
    What do you think ?
    Quan
    Well,
    i didn&#39;t test your files, yet. But in my firstlook I&#39;m wondering where do you tell the compiler to compile your source files?
    With the &#39;Hello&#39; Makefile you must have a toplevel c-source, which name is equal to your project name. In your case: myapp.c.
    Look again at the variable PROJ_NAME and PROGS in the makefile.
    HelmChen,
    Actually , the above makefile is taken from the Hello application which can be found in : C:\altera\kits\nios2\examples\software\linux\apps\samples\hello
    and this Hello project doesn&#39;t need SOURCE specified. When I tried this project , everything was fine : it could create *.gdb for me to debug , run , watch variable ,..... with it.
    My app and project names are the same. Anyway , I tried to add "SOURCE : file1.c file2.c file3.c" to my REAL project , which is much larger than hello app , but it could not create *.gdb although object file was created beautifully. I doubted at some "rm ..." commands in makefile and Rules.mak and tried to comment them out but it seemed that the "Build Make Target" didn&#39;t understand my changes. I am also thinking of NIOS 1C12 memory availability for my app (main is ~123772bytes , main.o is ~40200bytes).
    Is memoy the problem of mine ?
    What do you think ?
    Quan
