21 years agoBuffering Avalon tristate data bus
In order to implement a special access on tristate avalon bus, it is necessary to decouple parts of the data bus. I've done this by inserting a set of bidirectional tri-buffers. Their enables are...
21 years agoHi BadOmen & Jesse,
My original idea was to create an avalon slave (not tristate) together with some logic and merge it into the tristate side of the bus. There is a simplified diagram showing the basics what I've tried to do: ... see diagram ... (http://www.ing-buero-ruettger.de/nios/databus.htm) But if you look at the cyclone IOE structure, there is no physical way to insert these buffers. As Jesse posted, it is part of the "avalon to tri-state bridge" to merge input- and output-lines into a single bidir signal which is part of the IO cell. My design has to be done in the inner part of the tristate bridge. I think one possibility is to create an own avalon-to-tristate-bridge with a multiplexer and tri buffers, controlled by the appropriate CS signals. Thanks all for your help. Mike
