16 years agoBSP Editor Problem
I am trying to program my bootstrap code into on-chip memory and I am having serious problem with BSP editor.
1. In Quartus I am setting cpu to: reset vector memory onchip-memory offset 0x00 exception vector memory onchip-memory offset 0x20 2. Generate SOPC 3. Going to NIOS II - Eclipse platform and open BSP editor. 4. BSP editor displays a message: [Error] altera_linkerx_generator: The section mapping ".entry" mapped device "cfi_flash" is not the same as the SOPC Design specified device "onchip_memory" How can I change in BSP Editor linker script to map ".entry" to "onchip_memory"? Thanks!1 Reply
If the following doesn't work...
...you might have to generate a new BSP. You could also manually edit the settings.bsp file (XML format), but you'd have to know what you were doing. I've seen cases where some of the linker-related XML content in settings.bsp doesn't get properly updated when nios2-bsp-generate is run or causes it to crash. Good Luck! -slackernios2-bsp-generate-files --settings=<settings file> --bsp-dir=<target bsp files directory>
