11 years agoBooting NIOSII from .sof File
Hello, I am trying to boot the NIOS II from an .SOF file using memory initialization files (later, I want to boot from the .JIC file, which also doesn't work, but I want to start with this exam...
10 years agoProper way is to use EPCS controller in QSYS and boot using NiosII default bootloader (you would need that for larger code). In order to boot from on-chip RAM ( for very small code) you would need to edit your linker script from BSP Editor tool and set .text region point to that memory.
