11 years agoBooting NIOSII from .sof File
Hello, I am trying to boot the NIOS II from an .SOF file using memory initialization files (later, I want to boot from the .JIC file, which also doesn't work, but I want to start with this exam...
10 years agoI deinitely tried without --reset-target and using the push-button. I did not try manually loading the .sof file using memory initialization after this issue started occurring, not did I use system-console as I was not familiar with it.
The workaround was to switch from TCM to a normal memory, which magically started working.
