10 years agobooting nios2 from external OTP memory
Hi, I want to boot nios2 from OTP memory. The OTP memory is a EPROM device(Atmel OTP device) and has a parallel interface. It is not mentioned whether it is a CFI complaint or not. In nios there are 3 ways described for booting, in which one method has parallel interface and the other has serial interface, so, in order to boot from OTP i can use only CFI based booting method.Will the nios2 boot from OTP if i use the CFI based booting method ? or which method i can approach. Can anyone help me on this please...
