11 years agoboot NIOS and FPGA from EPCS flash
Hi all, I am having problems booting up my Nios C code from EPCS. I am building my own FPGA board, not using a demo board. I'm using Quartus 15.0 and DE0 NanoBoard( Cyclone IV as FPGA) My app...
11 years agoThank you Daixiwen for your answer.
After some modification in the code given above.Now, i can write and read to/from my flash device. But the problem i'm facing is that my data written to the flash are shifted, i can see that in the debug mode using the Memory. For example when i Write in the address 0x04FC0000, the data 0x3fa00000, Instead i see 0xF1050000. It seems to be shifted. The routine that writes is : /* write to flash 32 bits at a time */ IOWR_32DIRECT(epcq_flash_info->data_base, write_offset, word_to_write); word_to_write = 0x3fa00000. It's very strange. Do you have an idea what would be the problem? Thank you in advance. Best regards
