16 years ago
Boot loader and EPCS
Hi guys!
Another question about booting the system.
In my system i use EPCS flash memory, but not on-chip.
Is it still possible to boot the system from EPCS not on-chip memory?
I need a functionality to upgrade the application. According an458, only if flash memory is EPCS On-Chip Memory, i can upgrade the application.
Is it correct?
1 Reply
    I think there may be a little confusion here. Is your EPCS connected to the FPGA you want to use it on?
    When you use the EPCS controller in the SOPC system it uses a small amount of On Chip Mem to act as a bootloader, which contains the code to fetch the program code out of the EPCS controller and load it into program memory.
    The EPCS device is never on-chip memory, rather an external flash memory IC.
