10 years agoBluetooth Implementation in DE2-115 with uClinux
Hi everyone, I want to implement Bluetooth in Altera DE2-115. The board has a usb host (cy7c67200). I'm considering to use a bluetooth usb dongle to plug into this usb host to receive data fr...
10 years agoHi,
--- Quote Start --- By the way, I would like to ask, is Broadcom BCM20702A0 work well with CY7C67200? Because I plan to purchase a bluetooth usb first while I'm learning it for my final year project. May I know is this the one you are using? http://www.ebay.com/itm/gmyle-bluetooth-4-0-dual-mode-micro-usb-broadcom-bcm20702-adapter-dongle-/301333201181 --- Quote End --- I used I-O DATA's 'USB-BT40LE'. It's a Japanese maker, but the product is manufactured in China :-). Maybe other USB dongles which use Broadcom BCM20702A0 will work well. CSR8510 will not respond the command
< HCI Command: Accept Connection Request (0x01|0x0009) plen 7
0000: 3b f5 0d a6 e7 88 00 ;......
, and Nios2 will issue this when the CY7C67200 is used. Of course, I don't know the reason. Kazu
