10 years agoBluetooth Implementation in DE2-115 with uClinux
Hi everyone, I want to implement Bluetooth in Altera DE2-115. The board has a usb host (cy7c67200). I'm considering to use a bluetooth usb dongle to plug into this usb host to receive data fr...
10 years ago --- Quote Start --- I tested two Bluetooth USB dongles, CSR8510 and Broadcom BCM20702A0 on DE2-115 boards, but the combination CSR8510+CY7C67200 will not work well. Later, I will upload my test case on Altera Wiki. --- Quote End --- Hi Kazu, Currently I'm learning Bluetooth programming from this site. https://people.csail.mit.edu/albert/bluez-intro/index.html Hope it helps! By the way, I would like to ask, is Broadcom BCM20702A0 work well with CY7C67200? Because I plan to purchase a bluetooth usb first while I'm learning it for my final year project. May I know is this the one you are using? http://www.ebay.com/itm/gmyle-bluetooth-4-0-dual-mode-micro-usb-broadcom-bcm20702-adapter-dongle-/301333201181 Thanks a lot. Regards, Jun Mun
