14 years agoBit or byte swapping in SDRAM?
Hi, I have an Avalon-ST component sending data to an on-chip FIFO (ST input / MM output), which is read by a Nios CPU. I've verified that the data coming out of my component is valid both on a...
14 years agoI'm confident that my bit Verilog module is coded correctly and I'm not swapping bits. I found the problem to be in the Avalon-ST component definition. I had switched the "Data Bits per Symbol" parameter to 8 so I wouldn't need an adapter down the line.
So, my ST data bus is defined as "output reg [31:0] st_data" in the top level module. I assumed incorrectly that since my data bus is 32 bits wide, if I chose bits per symbol to be 8 then it would automatically set symbols per beat to 4 and my byte ordering would remain intact. What am I doing wrong here? -Jason
