14 years agoBit or byte swapping in SDRAM?
Hi, I have an Avalon-ST component sending data to an on-chip FIFO (ST input / MM output), which is read by a Nios CPU. I've verified that the data coming out of my component is valid both on a...
14 years ago --- Quote Start --- Is there any reason the Avalon-ST components would be doing the swapping? Is this an issue with the SDRAM controller? Having some trouble debugging, so any help would be appreciated. --- Quote End --- Be careful if you are coding in VHDL if you have code like this; signal d : std_logic_vector(31 to 0); signal q : std_logic_vector(0 to 31); since
q <= d;will bit-swap. Whereas
process(d)
begin
for i in 0 to 31 loop
q(i) <= d(i);
end loop;
end process;will retain the same bit index assignments between q and d. If you have instantiated an IP core with the bus bit order reversed, then you would see this as a bit-reversal in your final design. Cheers, Dave
