19 years ago/bin/init hangs
hi all,
I am trying to boot uclinux on 2s60 board. where my kernel is hanging moment it calls /bin/init. I have build uclinux with changed memory layout where base addresses and irq number differs then default memory layout .sof and .ptf files given by microtronix. Also I have remover support for compact flash in my case. I can boot uclinux build from microtronix .sof and .ptf file on the board with similarly generated file system. I tried "root=/dev/mtdblock0 ro" as well as nfs boot with root=/dev/nfs ro, and seems fine (nfs boot init gives error with init: execv failed, but get login and prompt ok) . But when I give my memory layout sof and ptf file the compilation is successful but kernel get hangs when he calls /bin/init. Any one has any idea why it is happing so??? Do I need to build new busybox ??? Is it not possible to boot uclinux with custom memory layout on Altera boards ?? Do I need to change my quartus-II 4.2 and nios-II 1.1 versions ??? Any suggestion where I am going wrong ??? If any one need I can post my sof, ptf and nios2_system.h files. thanks in advance Ankur
