10 years agoBest way to share DDR w/ FPGA
I have a rather simple task to perform but I don't know where to start. I'm using a Cyclone V SoCKit board. What I want to do is have the ARM processor write a data table in DDR so that th...
10 years agoIf the data you want to transfer is a (or a group of) memory block, I think the easiest solution would be to use the SGDMA or the modular SGDMA component. When configured as memory-to-stream, they deliver the data on an Avalon Stream Source interface which is very easy to use. Just put 'ready' to 1 when you can receive data, and when 'valid' is 1, you have new data on the 'data' signal.
