11 years ago
BeMicroMAX10: Nios II system skips first pattern of LED sequence at power up only?
Hi all,
I have this board set up so the LEDs show a pattern like this below with a one second delay between them:
LED1-LED2-LED3-LED4-LED5-LED6-LED7-LED8 (0=on, 1=off)
1110-0111
1101-1011
1011-1101
0111-1110
1011-1101
1101-1011
back to start
This works fine except at power up. The first pattern (1110-0111) is skipped. After the first time it works as expected.
I program the Nios following the tutorial in youtube from altera (link below) with ocram (initialized) and CFM0 . I have no flash ip in my design.
https://www.youtube.com/watch?v=0k4azmdw9sk
Why can't I see the first pattern?
    You need to post some code to help us. The make-up of your qsys system isn't going to hold the answer...
    Cheers,
    Alex
    As I was posting the code I saw the problem (i=1 should be i=0) so ... never mind.
