16 years agoBegin with nios by writing on a lcd
Hi all, i'm a newbie with the utilisation of sopc and how nios II processor works to begin, i would like to make a project with this simple goal for moment: use SOPC to create my own architect...
16 years agoIf you create an uninitialized static array, it will be put in the .bss section (I guess it is what you call the "read/write" data memory).
If you create an initialized static array, it will be put in the .data section. If you create it as a local variable in a function it will be in the stack memory. If you allocate it with malloc() (C) or new (C++) it will go in the heap memory.
