20 years agoBasics of „Timing Constraints“
Hello, For improving FPGA designs I’m looking for some basics about timing constraints. I would like to know: 1. when timing constraints should be used 2. which timing constraints should be...
20 years agoHello pavan,
Thank you for your response and the interesting link. Unfortunately the document describes the steps to optimize the timing. At the moment I don’t know if I should optimize anything because I didn’t setup any timing constraints, except the main system clock. And because of that the timing results are OK due to the fact that the one any only timing constraint (system clock) could be met. Here is an example of my problem in understanding timing constraints. The example is based on the serial DAC Ad5545 from Analog Devices. The device has four inputs: SDI, CLK, CS# and LDAC#. The signals are connected to the FPGA directly. The datasheets is giving some more information about the interface timing: CS# to Clock Setup (tCSS): 0 ns Clock to CS# Hold (tCSH): 10 ns; Data Setup (tDS): 5 ns Data Hold (tDH): 10 ns I know the meaning of the given timing information but I don’t know how to transfer this information into timing constraints. Regards, niosIIuser
