21 years agoBasic SDRAM/NIOS question
Hello: I'm new here. Here's a fairly basic question (I think)... an answer to which I have been unable to find. I have a NIOS2 cyclone development board. What I want to do is r...
21 years agoyesdingsheng,
Seems to me that you need a streaming PIO. Streaming is a seldom-used facet of the Avalon bus, but it fits the bill here. The HDL below implements a write-only streaming register; you can drive it from a DMA. You didn't say what version of the tools you have. The HDL should be importable from the Component Editor, or from the User Defined Interface with a bit more work. The new component should be defined as an Avalon Register Slave with 0 write wait states. Edit the Verilog parameters to suit your application. Let me know if this works for you. module streaming_pio ( // inputs: clk, reset_n, write_n, writedata, // outputs: readyfordata, pio_output ); parameter DATA_WIDTH = 14; parameter OUTPUT_RATE_HZ = 5000000; parameter CLOCK_RATE_HZ = 50000000; parameter PIO_RESET_VALUE = 0; // Calculated parameter (not editable in GUI). parameter RELOAD_VALUE = ((CLOCK_RATE_HZ / OUTPUT_RATE_HZ) - 1); input clk; input reset_n; input write_n; input [(DATA_WIDTH - 1) : 0] writedata; output readyfordata; output [(DATA_WIDTH - 1) : 0] pio_output; reg [31 : 0] counter; wire [31 : 0] p1_counter = (~readyfordata & |counter) ? (counter - 1) : (~write_n & readyfordata) ? RELOAD_VALUE : counter; always @(posedge clk or negedge reset_n) begin if (~reset_n) begin counter <= RELOAD_VALUE; end else begin counter <= p1_counter; end end wire readyfordata = ~|counter; reg [(DATA_WIDTH - 1) : 0] pio_output; wire [(DATA_WIDTH - 1) : 0] p1_pio_output = ~write_n & readyfordata ? writedata : pio_output; always @(posedge clk or negedge reset_n) begin if (~reset_n) begin pio_output <= PIO_RESET_VALUE; end else begin pio_output <= p1_pio_output; end end endmodule
