15 years agoBasic questions about FIFO, IRQs & DMA
Hello, i used a fifo from the megawizard library and introduced it into the SOPC system (just the DATA and the HALF_FULL signals the others signals are exported to outside the sopc system). How...
15 years agoMy system looks like this (attached image)
And here is my code#include <stdio.h># include <stdlib.h># include <stddef.h># include <string.h>
# include <system.h># include <io.h>
# include <alt_types.h># include "sys/alt_dma.h"# include "sys/alt_cache.h"# include "sys/alt_alarm.h"# include "alt_types.h"
static volatile int txrx_done = 0;
int i;
//callback function when DMA transfer done
static void txrxDone(void * handle, void * data)
txrx_done = 1;
void initMEM(int base_addr,int len)
for ( i=0;i<len;i++)
IOWR_8DIRECT(base_addr,10,i);
int main()
printf("testing ssram & sdram : dma operation\n");
alt_16 buffer;
//memset((void *)SSRAM_0_BASE,0x7a,0x10);//this write base on byte
initMEM(ONCHIP_MEMORY2_0_BASE,0x10);
// memset((void *)(SDRAM_0_BASE),0x33,0x10);
printf("content of ssram_0:before DMA operation\n");
for ( i=0;i<0x10;i++)
printf("%d: %x\n",i,IORD_8DIRECT(DMA_0_READ_MASTER_MY_FIFO_BASE,i));
printf("content of sdram_1:before DMA operation\n");
printf("%d: %x\n",i,IORD_8DIRECT(ONCHIP_MEMORY2_0_BASE,i));
int rc; //request
alt_dma_txchan txchan;
alt_dma_rxchan rxchan;
void* tx_data = (void*)DMA_0_READ_MASTER_MY_FIFO_BASE; /* pointer to data to send */
void* rx_buffer = (void*)(ONCHIP_MEMORY2_0_BASE); /* pointer to rx buffer */
/* Create the transmit channel */
if ((txchan = alt_dma_txchan_open("/dev/dma_0")) == NULL)
printf ("Failed to open transmit channel\n");
exit (1);
/* Create the receive channel */
if ((rxchan = alt_dma_rxchan_open("/dev/dma_0")) == NULL)
printf ("Failed to open receive channel\n");
exit (1);
/* Post the transmit request */
if ((rc = alt_dma_txchan_send (txchan,
tx_data,
0x10,
NULL,
NULL)) < 0)
printf ("Failed to post transmit request, reason = %i\n", rc);
//exit (1);
/* Post the receive request */
if ((rc = alt_dma_rxchan_prepare (rxchan,
rx_buffer,
0x10,
txrxDone,
NULL)) < 0)
printf ("Failed to post read request, reason = %i\n", rc);
//exit (1);
/* wait for transfer to complete */
while (!txrx_done);
printf ("Transfer successful!\n");
printf("content of ssram_0:after DMA operation\n");
printf("content of sdram_1:after DMA operation\n");
return 0;
