10 years agoBare-metal Execution Is Slow
I am using DE1-SoC to start bare-metal programming for dual-core Cortex-A9 ARM hard processor, Cyclone V.
I configured hps output clocks in qsys as follow MPU clock=800 Mhz, L3 MP clk = 200Mhz, L3 SP = 100Mhz, L4 (MP and SP) = 100Mhz. I write a code just to toggle hps pin, then a code to toggle fpga pin through h2f bridge as follow // my code to toggle hps hps_GPIO1[23] pin int main() { setup_peripherals(); while (true) { alt_xorbits_word(hps_addr, 0x800000 ); } } // my code to toggle fpga AJ22 pin int main() { setup_peripherals(); uint32_t *PIO_addr = 0xC0000000 + PIO_0_BASE; while (true) { alt_xorbits_word(PIO_addr, 1 ); } } The code worked but its toggling speed around 500 Khz, as you see it's very slow compared to ARM capabilities Then I turned on MMU unit and enabled cache system as follow mmu_init(); alt_cache_system_enable(); where mmu_init() get from http://www.alteraforum.com/forum/archive/index.php/t-46180.html. here the frequency of toggling increased to 1.3 Mhz. My Questions are, How could I increase the toggling speed? Is this the maximum frequency I can get? Is there a problem in hps init or configuration? I tested ARM clocks using alt_clk_freq_get( any_clk, &clk_freq)), I got frequencies as expected, but I am still not sure about this function.No RepliesBe the first to reply
