17 years agoAvalon Slave IP with Interrupt Receiver
We are trying to design an avalon slave that listens on the irq lines that are connected to the nios cpu. This slave should later on be able to count the individual irq's and freeze the nios w...
17 years ago<div class='quotetop'>QUOTE (MSchmitt @ Jul 24 2009, 04:30 AM) <{post_snapback}> (index.php?act=findpost&pid=23271)</div>
--- Quote Start --- your hack should be done as follows assign Sopc_Idle_0_avalon_slave_0_irq = cpu_0_data_master_irq; instead of assign Sopc_Idle_0_avalon_slave_0_irq = 0; Sopc_Idle_0_avalon_slave_0_irq is an input to my module so i do not understand why you create an output in the portlist as this input already exists and the cpu_0_data_master_irq has all informationen needed. thanks anyway[/b] --- Quote End --- No. You should define the irq signals input of your slave (perhaps called irqs) as an normal conduit input rather than a specialized interrupt receiver. In your top level module (of the project, not your IP's top level), define a wire like: "wire [31:0] system_irqs;" In the instantiation of system_0 in your top level module, add the new port to obtain the irq information: ".system_irq_out(system_irqs)," and pass it back into your IP by: ".irqs_to_the_Sopc_Idle_0_avalon_slave_0(system_irqs)," and put some comments in your top-level module to document the manual changes that were necessary to add the port in system_0.v This way, your IP is still a standard avalon MM IP that gets it's information the normal way by passing in the irqs info to one of it's ports from the top level project file. And I disagree that what I am suggesting is a "hack". If there was an option to expose the irq signals with a check-box in SOPC builder, the code would be generated almost exactly as I describe. Unfortunately, there isn't. I am 100% positive this is the most direct and correct way to do this. I would call it a necessary "work around" due to SOPC builder not having an option to expose irq signals to the top-level module. That is why I said it might be a feature request for the next version of Quartus II. P.S. Thanks for all the posts you make to help others. You are quite active!
