17 years agoAvalon Slave IP with Interrupt Receiver
We are trying to design an avalon slave that listens on the irq lines that are connected to the nios cpu. This slave should later on be able to count the individual irq's and freeze the nios w...
17 years agoHere's a solution. You need to modify the generated SOPC file to add a 32 bit output port in the port list (perhaps called system_irq_out).
Search the file for "module system_0" (or whatever your system is named). Add: "system_irq_out," in the port list. Define the port: "output [31:0] system_irq_out;" anywhere where the other ports are defined. Add: "wire system_irq_out = cpu_0_data_master_irq;" anywhere after the port list with the other wire declarations. then you have exposure of these irq signals to your top-level module, which can be passed as a normal 32-bit input signal into your custom IP. Yes....kind of sucks to have to do this everytime you re-build the system in SOPC builder, but it isn't too much work. Saves a lot of complexity for you. You have to re-adjust your thinking that this is a "hack". It isn't. The SOPC builder's generated verilog output for your system specification is just a verilog file, just like any other, as far as Quartus II's compiler is concerned. And it did 99.9999% of the work for you and did it very well. But, for your case, you need these IRQ signals, and SOPC builder doesn't have a feature that you can check to expose these signals. Perhaps it could be a feature request to be built into the next version of Quartus II. It beats making another memory master, and slave just to obtain the irq signals. To me, that is a hack, rather than doing it in a straight-forward way.
