11 years agoAvalon native and dynamic addressing
Hi all! I've already seen some discussions about native and dynamic addressing and interfacing peripherials with fewer address width. But this is still a bit confusing to me since there are ...
11 years agoThe type of addressing is controlled in a file with extension *_hw.tcl, which is used to describe and represent the core in Qsys. You should stick to dynamic as native addressing support is obsoleted.
Using the io.h to access the 8 bits interface of the I2C should be fine, you can use IORD/WR_8DIRECT. Qsys can help with the width adaptation.
