20 years agoAvalon Bridges
I have created a series of bridges that you may find useful to improve your FMAX or control how the Avalon switch fabric is created. See the below link to the project. avlaon to avalon bridge...
20 years agoWow - thanks for your excellent advices - I almost have a solution now!
A short resume of what I did: 1) The critical path was inside the Avalon switch fabric and related to the burst circuitry. Took down the burstwidth from 9 to 6 bits (max burst from 512 to 64) - we only need 48. This chopped the slack from -9 to -5 ns. 2) As a test case I took down the masters from 5 to 1. The slack went down to -1.8 ns - still not good enough. The critical path was now from the burst circuitry to the DDR2 controller. 3) Added one of your registered bridges between the master slave pair - and voila - achieved a slack of 0.5 ns plus reduction of 200 LE's! 4) Added back a master (from 1 to 2) and the slack was back at -3.8 ns. Critical path is now from the avalon_to_avalon_bridgest_0_avalon_slave_arbitrator to burst_0. Don't know what to do to fix this one. So it is clear that the Altera Megacor DDR2/Avalon/burst combination in a CycloneII -8 is struggling to achieve 125 MHz in general - and in particular with multi master systems. We will thus try to do the 4:1 arbitration for the high speed masters ourselves. Some further questions: - What does the current registered bridge do to the burstcont/how should it be set up? - Are there any conditions/terms to use your bridges in a commercial product? Looking forward to the new burst supporting version! Many Thanks & Regards, Ove Brynestad
