11 years agoAvalon 8 bit with Nios 32 bit possible?
It is possible to create a component (ex. UART) with avalon MM slave interface with 8 bit data width and use it with Nios II with 32 bit bus? I tried and compile fine but Nios II don't start on re...
11 years agoTry using signaltap to look at a real nios rather than using the simulator, or at least run the gate-level simulator talking to avalon slaves.
TCM is read every clock regardless of the instruction type. I can't find the actual note about reads, but under 'Data Master Port' in Chapter 2 of the processor reference (page 2-11 in the 9.0 version I've got an 'dead tree') it states "Byte-enable signals on the master port specify which of the four byte-lane(s) to write during store operations." - nothing is mentioned about reads.
