11 years agoAvalon 8 bit with Nios 32 bit possible?
It is possible to create a component (ex. UART) with avalon MM slave interface with 8 bit data width and use it with Nios II with 32 bit bus? I tried and compile fine but Nios II don't start on re...
11 years ago --- Quote Start --- As as far as I know the nios always asserts all 4 byte enables on reads - and discards the unwanted bytes later. The bus width adapters are also well known for generating master cycles with no asserted byte enables. If you also end up with a clock crossing bridge the transfers get very slow indeed. --- Quote End --- While it may be possible to create a broken system as you describe, or possibly it was a rule of thumb with older tools --- at least with Qsys your described behavior is not true. I think it must "work correctly" since Quartus 12 as that is where I implemented a bursting 8-bit slave and didn't run into the issue at that time. To test it again, I just created a dummy system in 14.0 with 8/16/32-bit slaves and a NIOS running this program:
int alt_main(void)
for(;;) {
IORD_8DIRECT(SLAVE_8BIT_BASE, 0x10);
IORD_8DIRECT(SLAVE_16BIT_BASE, 0x10);
IORD_8DIRECT(SLAVE_32BIT_BASE, 0x10);
IORD_16DIRECT(SLAVE_8BIT_BASE, 0x10);
IORD_16DIRECT(SLAVE_16BIT_BASE, 0x10);
IORD_16DIRECT(SLAVE_32BIT_BASE, 0x10);
IORD_32DIRECT(SLAVE_8BIT_BASE, 0x10);
IORD_32DIRECT(SLAVE_16BIT_BASE, 0x10);
IORD_32DIRECT(SLAVE_32BIT_BASE, 0x10);
Attached is the waveform. You'll see the 8-bit slave correctly get hit for 1/2/4 transactions. You'll see the 32-bit slave correctly get hit for 1 transaction with 1, 2, or 4 byteenables set. You'll see the 16-bit slave correctly get hit for one or two transactions with 1 or 2 byteenables set. In other words, it all kind of works like you would expect for a processor with dedicated byte/halfword/word {load,store} instructions and at least Qsys by default doesn't break anything.
