14 years agoAuto-Negotiation FAILED
I have a custom board with the 88E111 Ethernet PHY. At one point, the board would light up LEDs indicating a link has been made and it was in 100 mode. I did not change my design at all, but no...
12 years ago --- Quote Start --- I have a custom board with the 88E111 Ethernet PHY. At one point, the board would light up LEDs indicating a link has been made and it was in 100 mode. I did not change my design at all, but now I can't make a link. This first happened when I tried to plug the board directly into the LAN from the wall, rather than through the switch, in an attempt to get DHCP to work. I now have the board connected to a switch which goes to a PC and company LAN. The lights on the switch indicate that there is a physical connection made on the port the board is plugged into. They blink with 10 mode activity. But, the board doesn't indicate a link. Running the simple socket server design produces this output:
prepped 1 interface, initializing...
INFO : TSE MAC 0 found at address 0x08000000
INFO : PHY Marvell 88E1111 found at PHY address 0x12 of MAC Group
INFO : PHY - Automatically mapped to tse_mac_device
INFO : PHY - Restart Auto-Negotiation, checking PHY link...
WARNING : PHY - Auto-Negotiation FAILED
MARVELL : Enabling auto crossover
MARVELL : PHY reset
MARVELL : Mode changed to RGMII/Modified MII to Copper mode
MARVELL : Enable RGMII Timing Control
MARVELL : PHY reset
INFO : PHY - Checking link...
INFO : PHY - Link not yet established, restart auto-negotiation...
WARNING : PHY - Link could not established
WARNING : PHY - Auto-Negotiation not completed! Speed = 100, Duplex = Full
OK, x=0, CMD_CONFIG=0x00000000I am completely stumped on how I can't even make a link now, without changing any hardware or software. Before moving cables to plug the board directly into the wall, it would pass the auto negotiation and then fail at DHCP. I have gone back to the original setup exactly but the result is the same. No link at all. --- Quote End --- So did you finally solved this issue? I'm having the same exact message and running out of options. Thanks!
