14 years agoAuto-Negotiation FAILED
I have a custom board with the 88E111 Ethernet PHY. At one point, the board would light up LEDs indicating a link has been made and it was in 100 mode. I did not change my design at all, but no...
14 years ago --- Quote Start --- I seem to have fixed the problem, hopefully permanently, by adding a 100 clock cycle delay til I drive the ethernet PHY reset line high when the board powers up. --- Quote End --- Is it Marvell 88E1111 chip? Did You read the datasheet then? It needs about 50ms reset after power up. Kinda annoying bug.
