14 years agoAuto-Negotiation FAILED
I have a custom board with the 88E111 Ethernet PHY. At one point, the board would light up LEDs indicating a link has been made and it was in 100 mode. I did not change my design at all, but no...
14 years ago --- Quote Start --- You're sure the cable is connected correctly? Auto-Negotiation is a property of the PHY itself. You receive this value via MDIO interface, so it's MDI side problem. --- Quote End --- Yes, also I've switched cables to be sure. Do you think I may have a broken connector? I've also tried the setup in a completely different lab with different cable, switch, and wall connection and it did not make a difference.
