19 years agoAtomic compare_and_swap function
Hi all,
According the header file (D:\altera5\kits\nios2_50\bin\eclipse\plugins\com.microtronix.nios2linux.uClibc_1.4.0\include\bits\atomicity.h), the implemented function is only STUB (not really atomic!). Does anyone know how to do it really atomic? I thought that the simplest way is to disable the interrupt when doing this function and re-enable the interrupt afterwards. So I need to know how to enable/disable interrupt ?? Regards, Kwok Wong5 Replies
--- Quote Start --- originally posted by kwokwong@Nov 2 2006, 10:14 PM hi all,according the header file (d:\altera5\kits\nios2_50\bin\eclipse\plugins\com.microtronix.nios2linux.uclibc_1.4.0\include\bits\atomicity.h),
the implemented function is only stub (not really atomic!).
does anyone know how to do it really atomic?
i thought that the simplest way is to disable the interrupt when doing this function and re-enable the interrupt afterwards.
so i need to know how to enable/disable interrupt ??
regards,
kwok wong
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=19104)
--- quote end ---
--- Quote End --- It is not implemented, so we need a nios2 version in, uClibc/libc/sysdeps/linux/nios2/bits/atomicity.h Look at other arch, eg, arm,m68k,mips,i386, they use locked exchange instead of disable interrupt. Are there locked instructions in Nios2?
--- Quote Start --- originally posted by hippo+nov 2 2006, 11:52 pm--><div class='quotetop'>quote (hippo @ nov 2 2006, 11:52 pm)</div>--- quote start ---
<!--quotebegin-kwokwong@Nov 2 2006, 10:14 PM hi all,
regards,
kwok wong
--- quote end ---
--- Quote End --- It is not implemented, so we need a nios2 version in, uClibc/libc/sysdeps/linux/nios2/bits/atomicity.h Look at other arch, eg, arm,m68k,mips,i386, they use locked exchange instead of disable interrupt. Are there locked instructions in Nios2? <div align='right'><{post_snapback}> (index.php?act=findpost&pid=19108)</div> [/b] --- Quote End --- $ find uClibc -name "atomic*.h" uClibc/libc/sysdeps/linux/sh/bits/atomic.h uClibc/libc/sysdeps/linux/arm/bits/atomicity.h uClibc/libc/sysdeps/linux/i386/bits/atomic.h uClibc/libc/sysdeps/linux/i386/bits/atomicity.h uClibc/libc/sysdeps/linux/m68k/bits/atomicity.h uClibc/libc/sysdeps/linux/mips/bits/atomic.h uClibc/libc/sysdeps/linux/mips/bits/atomicity.h uClibc/libc/sysdeps/linux/alpha/bits/atomic.h uClibc/libc/sysdeps/linux/alpha/bits/atomicity.h uClibc/libc/sysdeps/linux/h8300/bits/atomicity.h uClibc/libc/sysdeps/linux/sparc/bits/atomicity.h uClibc/libc/sysdeps/linux/common/bits/atomic.h uClibc/libc/sysdeps/linux/common/bits/atomicity.h uClibc/libc/sysdeps/linux/x86_64/bits/atomic.h uClibc/libc/sysdeps/linux/x86_64/bits/atomicity.h uClibc/libc/sysdeps/linux/powerpc/bits/atomic.h uClibc/libc/sysdeps/linux/powerpc/bits/atomicity.h uClibc/include/bits/atomic.h uClibc/include/bits/atomicity.h uClibc/include/atomic.h If we create uClibc/libc/sysdeps/linux/nios2/bits/atomicity.h ,then it will become uClibc/include/bits/atomicity.h . Otherwise, it will come from uClibc/libc/sysdeps/linux/common/bits/atomicity.h, which is a stub. If nios2 does not have lock, then we can use disable/enable interrupr, with inline assembly.
TO_BE_DONE
Look in include/asm (ie, asm-nios2nommu) /system.h
Use, local_irq_save(x) // to disable global irq then, local_irq_restore(x) // to enable/restore global irq - Altera_Forum
--- Quote Start --- originally posted by hippo@Nov 7 2006, 12:47 AM look in include/asm (ie, asm-nios2nommu) /system.huse,
then,
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=19239)
--- quote end ---
--- Quote End --- Thank you, hippo! F.Y.I. Use the macro COMPARE_AND_SWAP in stead of the function compare_and_swap. E.g. static inline int __compare_and_swap(volatile int *p, int old_val, int new_val) { int result; unsigned long int_context; /* save int. and disable all interrupts */ local_irq_save(int_context); result = compare_and_swap((volatile long*)p, old_val, new_val); /* re-enable interrupt */ local_irq_restore(int_context); return result; } # define COMPARE_AND_SWAP(addr, old_val, new_val) __compare_and_swap(addr, old_val, new_val) http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/smile.gif
