15 years agoArria II GX AS support
I use ARRIA II GX EP2AGX260F35I5N device and EPCS128.Does that device support active serial (AS) configuration? Another question-how do i set the dedicated EPCS pins as regular I/O?On dual purpose...
15 years agoYou can use AS.
Look at here http://www.altera.com/literature/hb/arria-ii-gx/aiigx_51009.pdf You can set the dual purpose pin in the Quartus on compilation time. However, you only can use 7 out of 8 pins. The last 1 pin is dedicated to configuration.
