10 years agoArria 10 SPI Master bits per word support
Hi All, We are using Arria 10 SOC FPGA and interfacing SPI slave device which needs 20-bit stream of data as input. Here we have few questions on Arria 10 SPI controller. 1. What is ...
10 years agoThe technical reference manual for the A10 SoC HPS says the SPI controller supports data size from 4 to 16 bits. To access a device with 20-bit data you'll probably have to implement a soft SPI controller in the FPGA fabric and access that from the HPS. That would obviously require a custom driver unless you can find a soft SPI core that already has Linux support.
Good luck.
