Arria 10 EMIF on-chip debug
- 5 years ago
Hi Madis,
Unfortunately the decoding method is known to Intel Engineering team for advance internal debug purpose only. I don't have any doc nor the knowledge to share with you.
The only info assessible for external customer will be the info displayed in the toolkit itself.
Thanks for your understanding.
dlim
I don't recommend you to use "EMIF on chip debug" feature as it's mainly useful for Intel Internal debug only. Whatever calibration data log that you dump out won't be meaningful unless you know how to decode it.
Instead, may I recommend you to monitor DDR4 IP interface "local_cal_success" and "local_cal_fail" status signal with your NIOS software program ?
- These 2 status signals is good enough to tell your system whether DDR4 calibration process pass or fail
If unfortunately your system is really failing DDR4 calibration, then you can use EMIF debug toolkit to perform debugging and collect more debug info from there
dlim
