13 years agoARM DS 5 script to initialize and load code in SDRAM
Hi, My question is regarding the HPS core in Cyclone V SoC. I have successfully built and run sample code that came with ARM DS 5 using USB Blaster II interface. The code by default runs ...
11 years agoDear ixpress,
I think this is not in the "bootloading" topic. On Cyc V SoC DB, both the HPS-side memory controller , and FPGA-side memory controller has 1-1 GBs of DDR3 memory capacity. -If HPS side SDRAM is used I suggest to examine altera applications (after a properly installed Quartus + DS5 AE): <installed_altera_dir>\embedded\examples\software -If FPGA-side SRAM is used, I suggest to examine built-in template applications in NiosII_EDS. See memory_test template example. Formerly, I have successfully tried this above memory test template on baremetal level (ARM) with replacing of some SOCAL/HWLIB functions. See: <installed_altera_dir>\embedded\ip\altera\hps\altera_hps\doc\ (two different index.htmls) Best regards, Zsolt
