22 years agoAny example Master Ports available?
Hello, Altera or anyone else have an example demonstrating external master logic driving an SOPC system? I've got one "working" but only if I set a very low fmax. The particulars ar...
22 years ago --- Quote Start --- originally posted by kenland+jul 14 2004, 06:41 pm--><div class='quotetop'>quote (kenland @ jul 14 2004, 06:41 pm)</div>
--- quote start ---
the timing analyzer does complain, but i'm not sure what do do about it.[/b]
--- quote end ---
what are its specific complaints?
--- quote start ---
originally posted by kenland@jul 14 2004, 06:41 pm
for example the only logic connected to the address port is an lpm_counter that gets loaded with the sdram buffer address and then increments 4 times for each 32 bit word.
--- quote end ---
umm... four times? why not just increment by four? drive address[n-1:2] from the counter and drive address[1:0] with 0?
--- quote start ---
write_n is registered on cpuclk and either waits until wait_request is not active on a following rising clock.
--- quote end ---
you're supposed to keep write_n driven, not gate it with waitrequest. the write cycle starts when you want it to; this isn't like a shared bus where you have to wait for the other guy to get off of it. (well, actually, you do, but you wait by asserting write_n and waiting for waitrequest to go low. there's no separate wait-for-bus-release step.)
<!--quotebegin-kenland@Jul 14 2004, 06:41 PM do you think it can be the timing violations even though the la looks fine? --- Quote End --- It could be. Could you post just the ADC-to-Avalon master interface code?
