AWan01
6 years agoAn error occurred while executing the "make" command in order to create preloader file
I'm trying to compile a new preloader file using SOC EDS 15.0 on win10, but an error occurred while executing the "make" command. tar zxf /cygdrive/c/altera/15.0/embedded/host_tools/altera/preloader...
EBERLAZARE_I_Intel
6 years agoHi,
Just to confirm, have you run the SoC EDS as admin? You can right click and select "Run as Admin".
The error pops up after the make often causes by the file is not accessible, thus you need to run the SoC EDS as admin.
If this does not fix the issue let me know.
