16 years agoAltera TSE driver and example program for lwIP (1.3.2)
After many many requests and complaints about lack of support and/or documentation for support of lwIP for the Altera TSE, I have developed a drop-in TSE driver and example program and made this avai...
16 years ago --- Quote Start --- Hi! Many thanks to Bill for useful example and step-by-step pass-throw. I successfully compiled lwIP_NIOS_II_Example in EDS 10.0. A couple of minor issues I faced with: 1) steps 25-40. I tried to set paths and symbols through the GUI, but this didn't work. The workaround was to edit lwIP_NIOS_II_Example/Makefile manually. Also, to get “INFO” output like in Readme.txt ALT_DEBUG must be defined for lwIP_NIOS_II_Example_bsp project. 2) TSE-related components in SOPC must have standard names: 'tse_mac', 'sgdma_tx', 'sgdma_rx' and 'descriptor_memory'. If different names are used the code successfully compiles, but does not function. --- Quote End --- Hi Igor! Can you post your lwIP_NIOS_II_Example/Makefile please? Thanks!
