15 years agoAltera Template Web Server errors
Hello Users,
I'm new hear and have a little question. I Have Quartus 10.1Sp1 and NIOS II 10.1 Sp1 just a little Question: I will compile the "Template Web Server from Altera", but this makes some Problems. My Problem is,that takes some errors in the Comilation: in the alt_sys_init.c and triple_speed_ethernet_iniche.h : (1) 'triple_speed_ethernet_if' redeclared as different kind of symbol (2) expected '=', ',', ';', 'asm' or '__attribute__' before 'triple_speed_ethernet_if' why came this Problems? this files are standart Library files from altera. please, if somebody has an idea... thanks2 Replies
I have the same problem: (1) 'triple_speed_ethernet_if' redeclared as different kind of symbol Did you solved? Thank you in advance! - Altera_Forum
i have find a solution for my problem. The problem was, that i have choosen the wrong *.sopcinfo file. To make this right, choose the right *sopcinfo file and you have no error messages like this. Sincerely,
