10 years agoAltera-SoCFPGAU boot problem "CALIBRATION FAILED"
Hi. I am trying to get Helio Cyclonse V SoC board working Baremetal environment. And I am trying it by using Altera-SoCFPGA-HardwareLib-GPIO-CV-GNU for DS-5. A problem I am having now is on ...
10 years ago --- Quote Start --- It seems that helio having their own example rather than than from the altera one, http://rocketboards.org/foswiki/view/documentation/macnicaheliosocevaluationkit --- Quote End --- This is a very, very important distinction. The Helio might have different memory timing, so using an example that is designed for a different evaluation board will most likely fail. I'd recommend comparing the memory timings for the RAM on the evaluation board with the settings in Qsys, or just copy a Helio HPS model in to the Qsys that you are current using and replace the one there. You might need to be careful with the peripheral pin mapping and clocks, though.
