10 years agoHi Bhaumik,
I received an e-mail from Walter Goossens that probably doesn't apply to a single Nios II processor system but might apply to my system that has multiple Nios II processors that both are using interrupts. However, I thought I would send it along for your reference anyway. ***** Start of e-mail ***** Hi Brad, sorry for chiming in late (was on vacation). You mentioned earlier you had two nios2 processors connected in the same system. sopc2dts has a history of messing things up when there are multiple interrupt master for a slave component. You can eliminate the confusion by adding a irqmasterignore tag (see http://rocketboards.org/foswiki/view/documentation/gsrdv141devicetreegenerator#irqmasterignore_tag ) to eliminate niosB from niosA and vice-versa. Walter ***** End of e-mail ***** I don't know if it will make a difference but I will look into it later. If you try it, let me know if it makes any difference. - Brad
