10 years agoHi Brad,
See my comments below. --- Quote Start --- I will be interested in hearing about the output from your "cat /proc/interrupts" command. --- Quote End --- With working design, we are getting same IRQ numbers assigned to peripherals when we run "cat /proc/interrupts" command. See following : root:/> cat /proc/interrupts CPU0 1: 41566 NIOS2-INTC timer 2: 86 NIOS2-INTC sls-hcd:usb1 4: 70 NIOS2-INTC altera_jtaguart With non-working design, we are unable to run this command. Because after getting JTAG IRQ mismatch message, our control over console is lost. We are not able to write any command via Key-board. --- Quote Start --- Based on your previous comments, I assume you are using v3.10 of the linux kernel. Is that right? If not, what version are you using? --- Quote End --- Yes, we are using v3.10 of Linux kernel. Thanks, Bhaumik
