10 years agoHi Bhaumik,
Thank you for your responses. That clears up a couple misunderstandings I was having. It sounds like you are testing a system that is very similar to the one I'm using. I will be interested in hearing about the output from your "cat /proc/interrupts" command. Based on your previous comments, I assume you are using v3.10 of the linux kernel. Is that right? If not, what version are you using? I look forward to your response tomorrow. - Brad
