15 years agoaltasmi_parallel page writes
Consulting:
http://www.altera.com/literature/ug/ug_altasmi_parallel.pdf I have implemented the timing on page 11/ figure 11 (aka; Example 2) I have the PAGE_SIZE parameter set to 256 and thus I have 256 shift_bytes/wren/datain toggles before later asserting write/wren/addr after which busy is asserted for many cycles thereafter indicating a write to the EPCS. Problem is I read back the data as all 0xFF's. Prior to implementing page writes I performed single writes (disabled page writes in the mega fcn) and this worked (but took a long time naturally). Any ideas why page writes not working here? Is Figure 11 timing correct? I presume this is still a page size of 8 but only the first four bytes written with the rest left as 0xFFs. Does wren need to be asserted through the whole page write(and not toggle)? Using EPCS128. Thanks, CosNo RepliesBe the first to reply
