15 years agoalt_write_flash ERROR CODES
Trying to use alt_flash_open_dev() and alt_write_flash() and alt_read_flash(). alt_flash_open_dev() is successful but alt_write_flash returns an ERROR CODE = ffffff8c. Anyone knows what this ...
15 years agoThanks, Slack.
Will take it up with Altera support. I would expect the NIOS programmer code to not reinvent the HAL driver/API so I would expect it to use _some_ form of the driver/API that is either a version ahead(maybe I need to upgrade my tools from 9.1) or some cheeky little bug fix or workaround that did not make it into the main code stream. So, just got to find out what is different but I don't have the code so... We'll see. Cos
