8 years ago
alt_timestamp_start() return -1
hi
i build nios system with timer and set the bsp (timestamp,timer)
compile is ok
but when i run the alt_timestamp_start() get -1
and alt_timestamp() also return -1
!! the nticks() work good
i read post from 2005
""I can't see it clearly, but I think you set both your sys_clk_timer and timestamp_timer to be timer0? Can you disable the sys_clk_timer instead? Also remember to press the generate button.""
i was do this mistake too should i fix this ??
i fix that ""sys_clk_timer and timestamp_timer can not be timer0?"" i disable the sys_clk_timer on the bsp editor
tzahi
